Hello Guys, I need help, my engine is spitting much oil in the catch can, accumulates in a single run hard 1, 2, 3, 4, 5 max 7200rpm in gear, total of 1.2 liters of oil in catchtank. I've tried everything and nothing solved, Please help me, I will be eternally grateful
New engine too, I just rebuild is a RS2 ADU with the following parts below:
Scat Rods
OE Pistons
New Rings
New Bearings
New headgasket OE
Standard Block
Piston Rings, perfectly fitted to the right measures
Maximum Head Ported
Head (new seals, hi-rate New Springs, New Titanium Retainers)
Other parts:
- VEMS ECU
- Garret GT3076r .60 .78
- 2000cc Injector Dynamics ID2000 (100% ethanol fuel using e100)
- Wagner Inverted Manifold Intercooler Kit
- 034 Tubular Exhaust Manifold and Dowpipe
- Full 3 "Exhaust System
- High Output Coils LS1
Notes:
- The engine was run for 80km after rebuilt, now is set to boost 1.4bar max, max rpm 7500rpm
- Operation is Fine
- Compression Test, all cilinder is 11.5bar
- Head retight 80lb/fs already in ARP
- Oil level is OK not overflowing (I tried using half level, the problem continues)
- PCV system completely removed OE
- Installed directly on the crankcase Ventilation block and head for the CatchCan Oil (Catch Can connected to turbine inlet to generate vacuum). Hoses used -10an"
- Oil in catchcan is milky appearance
- Not smoke in exhaust
Anyone have any idea?
Sorry for my English
Eli Anderson
AudiRS2 - Brazil
Scat Rods
OE Pistons
New Rings
New Bearings
New headgasket OE
Standard Block
Maximum Head Ported
Other parts:
- VEMS ECU
Notes:
- Operation is Fine
Eli Anderson
AudiRS2 - Brazil
