Coolant Temperature
  • SamH
    • Nov 2008
    • 55
    Coolant Temperature
    I can't seem to find any thread relating to what coolant temps should be so was wondering what are ideal, safe coolant temps during normal running and hard/track use.
    Thanks in Advance.
    (sorry if this is posted elsewhere!)
    around 90 for normal use, I guess 90-105 maybe on track?
    • T2Andy
      • 1903
      If all is working well ,thermostat and no air locks you would normaly see just under 90
      and 1or 2 dashes above when working it really hard or sat in traffic hope that helps
        So what if the temp drops to just above 50 on the motorway? Does this mean the thermostat is fooked?
        • Veedub Geezer
          • Aug 2010
          • 46
          Sounds like the thermostat is stuck open.
          Current: Mk3 Golf GL 2.0 Estate
          Hers: VW Corrado 2.0 16v
          Next: Audi S2 Avant... Watch this space
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            no,
            the sensor that the dash shows the temp is in the water collector and it is sensitive to the changes in temp when on motorway.So it shows the temp dropping because of the cold air rushing through the radiators cooling everything down. If you'd check the sensor behind the the engine (white) with a laser gun, OR watch temp with vagcom, you'd see that the engine's temp is actually within the thermostat's parameters. Mine for example almost never goes below 70C (but i have a lower thermostat as well).
              when its at the mark just above 50 it is actually around 87deg The graduation on the gauge is not as it appears.
              87deg is the stat opening temperature so on the motorway this is seems normal to me
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                i got a little less 90Âş in motorway and a little more over 90Âş in city drive
                and in 20 minutes track use with 28ÂşC ambient temp i did only one or two marks over 90ÂşC with the heater at HI and 130ÂşC oil temp
                RED Mitsubishi Lancer Evolution VI TME nÂş 16 of 250
                BLACK Mitsubishi Lancer Evolution VI TME nÂş 189 of 250
                • SamH
                  • Nov 2008
                  • 55
                  ahh cool, been getting a couple of notches below 90c cruising and around 90c if i put my foot down. Changed waterpump and to samco hoses and drained coolant, so just wanted to check the temps before ADI.
                  Thanks for the reponses.
                  • SamH
                    • Nov 2008
                    • 55
                    Is it suggested to keep the heater on while your on track then to keep temps down?
                      A good trick is to PROPERLY short out the radiator fan switches - lot of frequent track day boys will actually have auxiliary switches and relays for this to flick the fan onto chosen speed... Its more for when sitting queued - once you get moving the cold air will do its thing... Oil temp is more of the concern but the S2 cooler works pretty well. Reckon on ~130 degrees oil temp when pushing some beans
                        Hmm, has to be said though that the heater goes colder on the motorway and a lot warmer in traffic..
                        Sorry for the hijack SamH
                        • johne
                          • Apr 2007
                          • 1404
                          Almost certain from what you've described that you need a new thermostat.
                          John
                          • SamH
                            • Nov 2008
                            • 55
                            No worries newsh
                            @s2central.net - what are save levels for the oil temps would you say?
                              I'd be worried much higher than 130 for oil... Others might have different view - depends on your oil too of course - though nobody should be run sub-standard oil here - especially at a trackday.
