Rough Running is driving me mad !
  • TheCod
    • 9
    Update On Events
    ok i have today checked the spark produced at the spark plugs and have established that plug 3 has no spark, I have checked the plug by putting it in one of the other leads and a good clean spark is produced, I have checked the lead to cyclinder 3 by changing cylinder 4's lead over to cylinder 3's output on the distributor cap and still no spark, I have recently had the distributor cap and arm replaced to try and resolve the issue, what other components are likely to prevent the spark reaching cylinder 3 ?
    Steve
      Check the static timing carefully. Its possible the dizzy is set wrong or the drive gear on the dizzy shaft is worn.
