HELP !! 2.2 20v S6 electrical issue
  • martinjs
    • 3205
    Where are you based?
    • fishbone13
      • Oct 2010
      • 69
      a long way from you by the look of things, Near Newbury Berks
      • s2_wot
        • Aug 2006
        • 2178
        Originally posted by fishbone13
        can i use just another ecu? is the immobilser system not run through the engine ecu?
        i am pretty sure that it is definately the ecu, tonight i disconnected all components and various relays and still popping the fuse, so not sure if its the best approach but i earthed pins 10, 14, 19 & 24 directly into the ecu which appear to be the main ecu earths (with the ecu unplugged) and put a fused feed into pin 18 (main feed)to simulate away from the car loom and i still get the same fault with the 5 amp fuse blowing.
        i am up for sending mine to see if it can be fixed but am willing to look on here for another ecu to try for now as long as its inter changable ie no immobilser issues wiith coding etc,
        i'm sure i saw one for sale on here from an aan
        thanks again people
        I don't fully understand the inner workings of the immo, but if you get the ecu from a car that doesn't have an immo my understanding is that you can just plug it in and fire up the beast without causing issues.
        Shane
        • martinjs
          • 3205
          Im near Aylesbury, if you dont find anyone local with an ecu to try, i dont mind coming over, you can try mine. (non immo but will work on your car)
          • fishbone13
            • Oct 2010
            • 69
            awesome that would be great, i will have a hunt around see whats for sale, but i might just hold you to that, obviously i'll cover your expenses etc
            • martinjs
              • 3205
              A non immo ABY (s2) one will work also, maybe put up a wanted thread. Pm me if you have no joy.
              • fishbone13
                • Oct 2010
                • 69
                have just done, thanks
                waiting for a reply for one in the for sale section.
                just really hope thats all the prob is , the last thing i want to do is shell out a load of cash to be no further forward
