wastegate exit pipe to exhaust
  • GazzaG60
    • 4133
    good point there CQ. it maybe this is the case
    i just dont like the restriction and im sure it will help not being there.
      Originally posted by Audi_CQ
      I tested my car on a dyno with different boost pressures, from 0.75 to 1.8bar, and the wastegate/WG pipe was hottest at the lowest pressure and not the highest. So much more exhaust had to pass the WG @ 0,75bar then @ 1.8bar. So high boost doesn't equal the need for a large WG in my case.
      Yep
      See http://www.034motorsport.com/dispell...ths-a-128.html
