Hi guys, need some help!
The black S2 I bought from Pix, with a 3071 in it, has developed a fault and I am not sure what it is.
Symptoms are;
Mostly mechanical boost only (~0.5 bar according to gauge)
Will sometimes boost above this in high gears until around 3.5 krpm
Faults found so far but unsure of how long they were up...
Intake pressure faulty (I cleared it and it has not come back up)
ECU memory error intermittant (cleared but not checked again yet)
The water temp gauge also stopped working and I found the two wires on the rear sender of the water manifold had dropped off, it also runs VERY cold (its freeeeeezing in the cabin!) but I suspect this to be thermostat and also very much unrelated to no boost!)
I checked the N75 by removing it and putting power to it, it works fine.
What next?
Thanks
Symptoms are;
What next?
Thanks
Thats a joke, cant be arsed fitting it to that car!
