Right Ive stripped the front from my car have bought a good quality timing belt and tentioner and new water pump. the new pump is ok looking but the impella is plasic,
removed the old gear from my car expecting to find a fooked plastic impella would you credit it its impella is metal and of much higher quality then the new one the new one has slotted holes for belt adjustment which brings me onto the old belt which was slack on the pump side you could twist it 90 degrees easily surely it should be tighter than that!?
so I`m taking the pump back the morn looking at getting a higher quallity one made from metal
the thermostat is sitting correctly see pic.
so my question is what the fooks gan on why is my car steaming the bottle should I change the bottle top?
if you remove the top from a normal healthy car would it start steaming and boiling over?
should I remove the aircon rad the pump is U/S any way
hopefully that'll have it sorted for you.
