Are the fuel lines on aby motors metric bubble flare?
  • Josh-stateside
    • 741
    Hi
    I cut my 7a fuel lines so I don't remember if they were bubble flare or not, or if the 7a connection fuel lines were for bubble flare. My dilemna is that I double flared them and i am leaking fuel when I go above 20% throttle. It's in the garage and it's not going anywhere so it's not a big deal to fix. Except for the fact that I am in the us and the bubble flare tool is rare. But is this true? I took the fuel lines apart and it looks to be the case.
    This is something new to me...
    Josh
  • Josh-stateside
    • 741
    Temporary solution:
    10m nut with built in washer inside the fuel line fitting. yes I am crazy. Yes it works. I need to solve some other problems before I decide what I want to do about this one.
    Cause money doesn't come from trees and metric bubble is a rarity and the tool to make one is $100 us dollars
    Josh
