have you seen something like this?
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Look what we found in an AAN engine...causing a non start...
    Have you seen something like this?
    sheared dizzy shaft?
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      No....worse...that is the camshaft!!!
      • prj
        • Mar 2010
        • 6308
        wtf...
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          exactly my words!
          • Pirvu Eugen
            • Apr 2007
            • 1978
            • Country: Romania
            The problem is that the 3B camshaft has not the same toothed gear as the AAN.
            This one had also play preloading...3B not.
                Wow!
                • nemilosu
                  • Nov 2008
                  • 196
                  • Country: Romania
                  i think i see this on a racing car.
                  • Billman
                    • 4129
                    It is at the end of the camshaft. I have a pair of AAN Cams and the material of the gear looks to be the same as for the rest of the cam. Dont know if this one is simply dirty or brass.
                    The cams are up for sale if you need a pair.
                    Go Holset or Go RS4
                    • spink
                      • 4382
                      Think this happened on toms(audimans) 550+bhp S2 a few years back
                      • nemilosu
                        • Nov 2008
                        • 196
                        • Country: Romania
                        price please.
                          I think the early AAN "dizzy" (Cam Tensor in a Tuna Can) drive gear on the AAN intake cam is a shrink fit. You can see where the drive gear fits on the cam in these photos (one without the gear, one with) (See below)
                          Here is a link to general G40 Cam Position Sensor Info
                          • Pirvu Eugen
                            • Apr 2007
                            • 1978
                            • Country: Romania
                            I see some diferences between the teeth on the cams and the actual teeth from the distributor...there were 2 types?
                            • rs200
                              • May 2009
                              • 1398
                              • Home: Croatia
                              omg...
                              I would say this is impossible ... how can this happened on Audi?
                              you can now use this cams for engine which have hall sensor under the cams pulley..
                              just like people said "everything is possible"...
