How does the tamper proof thing come off i spent ages trying to feel for a bolt and now i know why!
Non-starting
Hammer and chisel! its the easiest way, then dont fit it again. its not needed. then there is a 13mm headed nut under it. Remove the IM first, its so much easier.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Yeah I know, was very shocked when I ordered itsigpic
Audi UR Quattro
Originally posted by Greenm3**** i cant see a thing... this has to be one of the most difficult dizzies to get at....does anything on top have to come off first or am i ok going in blind from underneath?????
im ata bit of a loss here....
PaulPaul Nugent
Gitsigpic
Audi UR Quattro
my thoughts exactly.
When taking the inlet manifold off are there any torque settings i need for putting it back on? and will i have to replace any gaskets? Thought i better ask this first so that i have all the bit's i need before i jump in head first!
Yes you'll need gaskets for the IM... Best to have a darn good look at two link hoses for the water system when you have that out of the way. They are prone to failure. You might also consider thermostat at the same time if you have any doubts on your existing one - just to save you time down the line.Paul Nugent
Originally posted by Greenm3any one know where i can get this tool from?
Mike
well if you have about a 10" 6mm allen key that will do
theres no need to take the throttle body off. leave everything attatched to the IM.
martin
