500HP target turbo - GTX30 vs ?
  • mastermind
    • Jan 2005
    • 244
    • Country: South Africa
    Hi Guys
    I know this subject has been dealt with a million times, but times they are a changing..
    I have a kkk/3071 atm and am looking at the new upgrade from Garrett. The new GTX 3076seems to be the one I should go for. Is anyone else looking at this upgrade?
    However is there something else I should be considering? With better spool and will support 500 or so horses..? in other words the Miracle Turbo
    I use the S2 mainly for Hillclimbs.
    I have previosly done the bottom end with parts supplied by 034. I will now be using the short intake kit from Wagner and Vems ECU.
    The Red Baron
    (R)S2 spec, 034 GT3071
    Wagner Short Intake and Intercooler
    Whiteline, Custom Shocks with external reservoirs
    8pot calipers with A8 discs
    Vems
  • Thuppu
    • 4115
    I just got a CT5658 BB turbo. I was promised with superb spool and 500+hp. Lets see when I got it fitted...
    • button
      • Dec 2007
      • 99
      • Country: Poland
      Only HX35:
      1,8bar boost
      Audi 90 quattro '88 4.2V8 on VEMS
      Audi S4 C4 Avant 2.2T '92 @ 2,5TDI
      • mastermind
        • Jan 2005
        • 244
        Thnx Guys
        I beleive that the CT and precision Turbos flow better than off-the-shelf units, so will look at it.
        There has not been much comment here on the GTX's so I presume its too new to really say.
        The HX35 seems to have been ahead of the GT's but I think we need to wait and see if the GTX's prove better. Do these fit on the standard Manifold, i.e. KKK hot side?
        Anyone else have experience with a turbo that spools like a GT3071 that will yeild 500+ HP?
        The Red Baron
        Vems
        • Billman
          • 4129
          I just looked at some pictures and it seems that garretts idea of high flow turbo is to remove the secondary blades of the compressor impeller and actually make a billet aluminium turbine impeller :-p
          What is the effect of secondary impellers??? Don't know for sure but i am guessing that since the turbine wheels doesn't have some (and turbine weels must flow well with much exhaust gas) i am thinking that they are there to provide enough flow at slow impeller speeds and that would mean that these
          turbos will for sure be worse low down than their equivalent but it would make their surging issues better.
          So to sum up i would say that they made the impeller design actually better by reducing weight (billet and no secondary blades) and going back by 50 years in impeller design.
          What is your opinion?
          Here some pictures for reference
          Garrett GTX
          Precision Billet
          Holset Billet
          Compturbo Billet (could not find a better picture)
          Go Holset or Go RS4
          • keithsw0
            • May 2005
            • 571
            i have gone for precision 5557 and was also told that i will make 500 and spool as quick as 3071 fingers crossed
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              Originally posted by mastermind
              Thnx Guys
              the GT3071 0.63ar at 2.0bar coul be??
              • Billman
                • 4129
                At 7500 and 2 bar its far outside the compressor efficiency map and with the 0.63 the back pressure would be too excessive.
                Go Holset or Go RS4
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  i believe so as well that spooling will not be too much affected unless there is a turbine downsize. so 0.63 would be too constricted on the high rev area. i have been tuning an rs2 with the 3071r turbo 0.63ar these days here in greece for 95octane fuel and sure, the amount of boost it can create from down low is very good as it starts very early but it also runs out fairly fast. so fairly ideal mid range turbo.
                  • mastermind
                    • Jan 2005
                    • 244
                    I dont have enough knowledge around the impeller influence to comment intelligently about the new design yet, but will do some further reading up.
                    The 3071 on my car atm holding 1.6bar to red line does 450HP, but with race fuel and everything else being perfect.
                    Maybe the new GTX 3071 will give over 500HP but the current 3071 wont reach it on the S2, maybe with some other major changes, but then will the 0.63 A/R cause excessive back pressure and high egts when chasing 500 with the new GTX 3071?
                    Precisons 5557 looks good. Do you know where I can get Comp Map for this turbo?
                    The Red Baron
                    Vems
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      a car of a friend of mine did 523hp with 683nm with GT3071 0.63ar .... with the oem exhaust sistem,without cats.and with Wagner front instake and BIG IC....
                      do you know if is it possible?? or there is something wrong and totally crazy?
                      • diesel des
                        • 3896
                        Yea, the gt3071r will flow for 500hp. But I wouldn't run it like that for track work.
                        Turbos are always a compromise, and the one you have is amung the best for quick spool 450hp. Will 10% more power really be worth chasing, at the expenses of slightly more lag?
                        If so look at the new bw ceramic ones coming out, not the gtx garrett.
                        • mastermind
                          • Jan 2005
                          • 244
                          I dont think its possible, but your friend may have other work done to the engine to increase the Volumetric Effiecency and I also tried to use higher boost (1.9Bar) and found egts going very high, timing pulling back but huge Nm on my car.
                          I am also installing the Wagner Short Intake with Intercooler and install my VEMS as well, so this may give me the 450HP consistantly, but is not enough for the hillclimb events I also use the car for.
                          The Red Baron
                          Vems
                          • mastermind
                            • Jan 2005
                            • 244
                            You absolutely right. I have been thinking about this and if the miracle turbo is not available (3071 spool with 3076 power) then maybe its worth looking at 550 HP. considering 7A cams (RS2 cams atm), and rev higher for 550HP.
                            But there are those that say the HX35 , the 5557 and as you mention the BWs may offer what I'm looking for. So I will have to look at the comp maps of these and try and go by the experience of others and then make a decision.
                            The Red Baron
                            Vems
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              comp maps are not available. you need to trust them.
                              no matter how much i tried before buying any other turbo than the 3071,the comp people are not giving out any info unfortunatelly
