500HP target turbo - GTX30 vs ?
  • Billman
    • 4129
    #61
    Nice to see this in the forum!!! I like this attitude! Cheers guys
    Go Holset or Go RS4
    • diesel des
      • 3896
      #62
      I'm interested to see what difference the smaller housing makes. Maybe it will surge?
      • mastermind
        • Jan 2005
        • 244
        • Country: South Africa
        #63
        Or it may prove to be what I am looking for
        The Red Baron
        (R)S2 spec, 034 GT3071
        Wagner Short Intake and Intercooler
        Whiteline, Custom Shocks with external reservoirs
        8pot calipers with A8 discs
        Vems
        • repo
          • Dec 2004
          • 893
          3500rpm and 2bar from a super40? with what hotside and which gear was the pull made?
          it was statements like these that made me try the super40 and then realise that you either need to invest 10K euros on engine parts to make the turbo have such small amount of lag, OR it is just not possible.
          I am sorry, I made a typo earlier, that engine was NOT with 7a cams. And yes, it was more then 10K build.
          I tried to look for logs, but I didn't find any, I have made some silly names to the files apparently, and it is pretty hard to recognize them from each other, especially when You have thousands of logs on Your computer...
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #65
            excactly my point.
            So once again, in order to say lag and spool and rpm that you get the highest boost at, it is not worth discussing only turbos, its also worth discussing on which setup this was done. Otherwise different impressions are made
            • repo
              • Dec 2004
              • 893
              Isn't that kind of a self clarity?
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                #67
                im not sure what you mean by that
                • URQguy
                  • Sep 2008
                  • 245
                  I would love to see the boost profile, and the power/torque produced by such an odd combination. What cams?
                  1981 URQuattro with the TIAL GT35r.
                  2007 Infinity g35
                  • repo
                    • Dec 2004
                    • 893
                    Dyno plot.
                    I do not have the boost profile.
                    Boost is always late on this dyno, so dyno boost profile would be useless.
                    • URQguy
                      • Sep 2008
                      • 245
                      Wheel or calculated crank hp based off drivetrain loss/roll down on the dyno. What dyno is it? Load based? Doesn't matter much, as they are just profiles. Interesting though. You think this motor/tune is seeing 2bar at 3500?
                      2007 Infinity g35
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #71
                        is the gear of the pull 4th or 5th?
                        i would dangerously assume that if this turbo was seeing 2bar from 3500rpm, it seems weird to only have about 300Nm of torque. Judging from numerous logs i have done with 3 different turbos on my engine, i would say that the full boost (at least on the dyno), comes somewhat at 4000rpm where the torque curve starts to become steep. That i would believe, in which case it is not far off from my experience with the HXSuper40, which gave me 1.8bar @ 4200rpm on 4th gear. (1.8 was limited by me, as i didnt bother trying 2bar with that turbo).
                        • repo
                          • Dec 2004
                          • 893
                          Now You two boneheads, did or did I not write in completely understandable english:
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            #73
                            if you read again you will understand that i agree with you on this one. BUT as always, you write first and then think....
                            i wonder who the is the real bonehead...
                              I love the Repo replies
                              • URQguy
                                • Sep 2008
                                • 245
                                Bonehead? My friend, you have mistyped a handful of posts on this thread alone. It is hard to understand this setup of yours after 5 pages of thread. I speak several languages and have spent several years in other countries and understand the barriers associated with wording, but I try not to call others "boneheads" when I fail to communicate effectively.
                                I have been on plenty of dyno's too. They make boost "later" than on the road, but not 1000rpm+ later as this dyno is indicating. Also I have never seen 3b/aan/aby turbo cams make power above 7000 like this plot does. That is why I asked further about hte setup above. I wanted to know what dyno, if it was load based, if this is calculated WHP/WTQ and if you think this motor/tune is making 2 bar at 3500 on the street. I don't think so, but I am curious if you do. I have been wronge plenty of times in life, this year, and even this week. Perhaps I am just up in the night again.
                                2007 Infinity g35
