Is it possible S2 Turbo to Hybrid Turbo ?
  • ian4455
    • Nov 2010
    • 787
    Is it possible to make a hybrid turbo from a standard S2 Turbo ?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    of course¡¡
    please talk with Richard "Hoffer76+" Forum member here,he can help you sure¡¡ because hi did a rebuilt one with faster spool and better topend ( 330hp max )
    • prj
      • Mar 2010
      • 6308
      Except that "330hp" claim is out of thin air, because no dyno numbers have been posted...
        Hybrid turbo is a bit of a Max Powerism, what are you actually after? There are turbos of all sizes that you can use to get a desired power or driving characteristic, it's what else you need to do at the same time that's the fun part...
        There are a few turbos that are sized between S2 and RS2, these are usually referred to as small hybrids. Richard's uses a more modern, lighter comp wheel and so is supposed to spool faster. Different comp map also means you can run a tad more boost. MTM, Turbo Dynamics and AET all offer options but few other than MTM are tried and tested.
        • hoffer76
          • Mar 2008
          • 230
          yes 330bhp is out of thin air, I am expecting 305 reliable and 315/320bhp maxed.
          various people have this turbo now so not long till somebody posts a dyno for you.
          • prj
            • Mar 2010
            • 6308
            Well, until they post it, any claims remain thin air
            I am not saying it won't work, I just don't like "made-up-on-the-spot" numbers.
            • HMS-S6
              • Jan 2010
              • 1164
              Do you come on here simply to argue?
              • driftin jo
                • Sep 2007
                • 2222
                I cant see the point of changing the standard turbo for one that only makes 15-20 HP more .
                • HMS-S6
                  • Jan 2010
                  • 1164
                  I think it'd be good if you have a tired k24 and not thousands to throw at a car? Think the spool is different too
                  • driftin jo
                    • Sep 2007
                    • 2222
                    You have still got to map the the thing and to me that's a waste of money for 20 HP, for me the minimum upgrade would be +100 to make it worth wile doing .
                    • prj
                      • Mar 2010
                      • 6308
                      No, actually I am quite interested in whether this combination actually has an advantage.
                        A variety of opinions is what is the spice of life and pushes the boundaries of knowledge and experience for all of us.
                        Plus I love the electricity in these threads.
                        Let's all learn from each other, instead of giving out if someone doesn't agree with your own point of view.
                        Kind regards.
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          that´s true, but i am complete sure that Hoffer76 could let a hand on it for a right price turbo/software combo
                          • HMS-S6
                            • Jan 2010
                            • 1164
                            True, once my S6 is running right i want to pay him a visit for a K26/27 upgrade, but untill it'll at least run ok in standard form i have to wait
                            • pixsaudisex2
                              • Sep 2004
                              • 3110
                              I had one from turbo dynamics (through dynathingy) Never actually knew what was different but the car may have only been a wee bit more powerful but im sure it was more powerful much much sooner than standard. In simple terms..
