Head gasket for 82,5 stroker....
  • JP
    • 1858
    Milling out a Headgasket is a no no. Quite simply you get too close to the firing ring. The exact thing that seals the bore from the engines oil and waterways.
    Such is the extend of the effectiveness of the firing ring that once you have fitted a metal multi layer Headgasket you can't go back to a fibre one without decking the block as otherwise it doesn't seal properly from the indentations created by the multi layer's firing ring.
    Now as a reference point the reason an 81mm bore engine comes with an 82mm bore gasket is to allow for of the shelf 1st and 2nd oversized pistons. So you can use the stock gasket with an 82mm piston. To go to an 82.5mm bore the only of the shelf option would be to ring the block and use the fibre gasket of the 7A lump which favours the bigger bore size.
    Much the same as you would with a copper Headgasket. Although instead of paying big money for a copper gasket you can use the stock cheap fibre one with the same results.
    UrS6 Stroker + HTA3586 =
    • JP
      • 1858
      Originally posted by Billman
      It's ok if the gasket protrudes in the combustion chamber even if the piston clears it?
      Not really ideal as it makes the engine prone to knock. It also starts to eat away at the gasket potentially causing failure in-between the layers. Rather than across the sealing surfaces.
      • andy10v
        • 5996
        Would that not create a hot spot and therefore possible detonation?
        Sold ABY-stock
        • gnutz2
          • Aug 2006
          • 928
          First i tried an Elring gasket and machined it out, it was then i saw the fire ring come off.
          This (0.1mm) layer was folded back about 3mm maybe less.
          Then i tried a Payen and realised Elring and Payen are the same.
          Not tried Victor Reinz but assumed they would have a similar fire ring.
          My pistons just come proud of the block so i cant just put a standard gasket on without machining the pistons. I may go down this route as the gasket only protrudes the cylinders by .25mm.
          I dont really want the trouble of o-ringing the block, but if i was aware there was so little aftermarket gaskets available i may have done it when the block was bored.
          If only it was a 1.8t i would have any gasket i wanted.
          The ONLY S2 Golf!
          http://www.s2forum.com/forum/showthread.php?t=19402
          10.42@138mph
          https://m.youtube.com/watch?v=0wnkkOfFpXg
          • JP
            • 1858
            ^^^^^ firing ring is in the same location on all of them otherwise once you use one manufacturer you can't use another one due to the indentation left on the block so they end up having a standard across the board they have to adhere to.
            • th.b.w.
              • Nov 2006
              • 98
              Hi,
              that mean we have 3 options...
              1. Use the stock 82mm multilayer gasket.
              >Is this so critical with the 0,25mm undersize ???
              2. Machined the 82mm to 83mm stock gasket.
              > A user in Germany did this, i call him ...
              3. Buy a 83mm from PKM.
              > expensive...
              Have someone tested the 7a gasket ?
              Thomas
              • JP
                • 1858
                A lot of the cossie boys have gone the route of ringing the block and using fibre gaskets for high boost application as the multi layer metal rallye gaskets for the cossie's seam to let go with over 2.5bar of boost.
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Can you offer a O-ring service JP?
                  Chef
                  • gnutz2
                    • Aug 2006
                    • 928
                    Does the o-ring sit on the steel part of the fibre gasket (stupid question maybe)?
                    Also how far does the ring protrude the block deck?
                    The ONLY S2 Golf!
                    10.42@138mph
                    • th.b.w.
                      • Nov 2006
                      • 98
                      what means o-ring the block ?
                      Any picture ?
                      • caterpillar
                        • 2480
                        #26
                        o-ring
                        Any picture ?
                        it means: you have to mill a 0,8mm ring groove around the syl( in the block surface) then you have to put in some sort of pianosteelWire) , the wire does have the oversice , so its about 1,0mm)
                        the ringgroove have to be done in the maschineshop, where they rebore the syl...., and i have it told it shuould bee about 2mm from the syl surface,on the gasgedplace...
                        when you have the gasged om, it will bee some more pressured together where the O-ring of wire are, and hold the gasged in correkt posisjon
                        • caterpillar
                          • 2480
                          #27
                          headgasgeds
                          the 2,3liter gasged does fit( its 82,5 syl )but can you get it in MLS?? the NG(10v) and the 7A( 20v), then you does have the 2,6liter in the vw africa, and in some eurovans
                          • th.b.w.
                            • Nov 2006
                            • 98
                            This must be the right one....
                            Multi-layer Steel Headgasket 10v/20v hyd. $95.00
                            OEM Quality, factory specification Victor Reinz multi-layer steel headgasket, fits all hydraulic lifter Audi/VW 5 cylinder motors (20v including 10v) with up to 82.5mm bore. A must do for replacement of much weaker pressed paper gaskets.
                            In Stock!
                            ....and the price is okay....
                            Thomas
                            • gnutz2
                              • Aug 2006
                              • 928
                              I would be careful, why would a victor reinz gasket have a different bore to all other HG's.
                              I once bought a 12mm cnc cut exhaust mani flange from 034 and when it came it was 10mm
                              The ONLY S2 Golf!
                              10.42@138mph
                              • th.b.w.
                                • Nov 2006
                                • 98
                                Hi,
                                do you realy think it is an stock gasket ?
                                I will ask him from 034 and see....
