Failed MOT on emissions? any ideas
  • Rikki Kitto
    • Feb 2010
    • 6276
    Might have emissions problems for MOT any one know how hard it is to sort out
  • Acidburn
    • 13459
    have you got cats fitted first off?
    secondly did you take it for a spin before hand - i mean proper spin to get them hot as hell as that helps.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Cars been stood for three months in a warehouse, only started it up and drove it a few miles. Think it has got cat not sure.
      • caterpillar
        • 2480
        have you change the oil in engine? airfilter? the oilleekin turbo( in the exos) will kause bad emission too..
        • Acidburn
          • 13459
          as above, get it warmed up good an proper and also its worth checking filter and doing the oil as caterpillar's mentioned
          • dubmeister
            • 522
            Has to have cats fitted or you are pissing in the wind!!
            Give it a damn good thrashing before hand, to warm everything up and clear the ***** from the exhaust.
            If you are convinced it will fail, give it a service (oil/filters/plugs), check the exhaust is leak free. I have used cataclean on cars that were marginal failures to get them through.
            and yes it DOES work and i am an MOT tester.
            If you take it and it fails make sure you get a copy of the test and post up what the figures are (CO, HC and Lambda) and i can point you in the right direction to get it through.
            • Rikki Kitto
              • Feb 2010
              • 6276
              Thanks for the advice guys will keep you informed back in next week sometime for a retest.
              • Ross
                • Aug 2005
                • 3399
                ...or have it melt the probe and it'll get through. That was the alleged story on my decatted RS2; my MOT tester did tell me I'll need cats next year though
                As others have said, get the cat right up to temp - I had issues with the sport cat on my S2 last year, finally got it through after a few tries, but it hadn't been thrashed properly.
                Oddly enough this years MOT on the S2 the tester said the ABY engine could legitimately be passed on the older test; he spoke to VOSA - told me it was something to do with it being listed as a 2.3 opposed to a 2.2. Aparrently the ADU was listed correctly though
                  My avant went through ok with (empty) cats
                  • quattro_king01
                    • Mar 2010
                    • 6
                    mine got mot with no cats on old test reading . up to 1995 reg up to 3.2 co i think ???? (1993 aby)
                      I think on a 1990 reg car like mine you can get away with more emmisions that a coal fired power station
                      Mine with no cat was less than 10% the CO limit
                      • DamianURS4
                        • May 2010
                        • 406
                        3" system - straight through - no cats - the MOT tester re-callibrated his system because the reading was so low he thought it was off - he then tested a 4 year old car which gave a higher reading than my old girl. It does however say in the notes that my exhaust is 'loud'.......
                          haha, just in case you hadn't noticed
                          • DamianURS4
                            • May 2010
                            • 406
                            I was like 'WHAT?????? WHAT?????1 lol!!!
                              I think mine come up about 0.5 CO, with Mihnea chipsets..
                              The avant would fail on oil burning at the mo though.. new turbo and rings going in this week.
