could a dodgy voltage reg stop car starting?
    Originally posted by avants2turbo
    the ones youve ordered from the other side of the pond dont come with the connector though do they? you have to splice them into the origional connector? and its the origional connector I have managed to ****** up! or do they come with the connector?
    The ones from BB Automacao, the one's that I highlighted in the G40 replacement DIY I pointed you to (my previous post), do not come with the connector end. I have also pointed you directly at the PN for the replacement connector but you seem to have missed that. In your case, based on your approach to replacing your clutch pressure plate, you need to remove your engine from the car and install a 034905161 camshaft position (Hall) sensor, Item 10 in this diagram:
    • avants2turbo
      • Feb 2008
      • 1287
      very funny, ill tell you what, put a poll up asking who would replace the pressure plate by removing the engine, or removing the gearbox, ill bet more people would rather remove the engine than the box
      • johne
        • Apr 2007
        • 1404
        No, they don't come with the connector, you have to splice/solder the wires to the wires leading from your old connector.
        John
        • johne
          • Apr 2007
          • 1404
          Twice because that's how many times I've renewed my pressure plate and engine out is the only real option if you haven't got a lift to get the car up in the air. Support the engine and roll the rest of the car away from it is the way to go!
          John
          • rj scotty
            • May 2006
            • 2195
            #20
            Made this mistake on my old V6, engine out far easier don't even need a hoist
            BUT I DON'T WANT A NEW CAR!
            1995 S2 Avant, Volcano Black
