Another non starter!
Breif history-
Car running fine only problem seemed to be dodgy voltage reg (lights going up and down on idle and with revs etc)
Parked up one night, raining that night, went to start next day, tuned over, almost fired, then just turned over and over.
Replaced the 2 crank sensors a few days later, it fired up. Drove the car to my workshop, then back again, parked up, next day same again! Tried almost to fire one then just turns over and over.
Left it a couple of weeks with this crappy weather, tried to start it just now same again, almost fired once, then just turns over and over.
Just done a blink test and only get 2111 (g28 i beleive) which i understand should come up if the engines not running?
I dont think ive got a timing/crank keyway shere as it didnt work, then did then didnt and ran perfectly when ut was running (apart from the voltage fluctuations)
Breif history-
but be carefull not to bend the pipes...
