G40 camshaft position sensor PN??
  • avants2turbo
    • Feb 2008
    • 1287
    anyone know the correct PN for the G40 sensor, just spoke to my mate at VW and the part number he can find is
    034 905 381 or 034 905 381A
    are any of these correct?
    I put the part number into google and it comes up as a crankshaft pulse sensor?
    G40 Cam Shaft Senor Info including PN
    Originally posted by avants2turbo
    anyone know the correct PN for the G40 sensor, just spoke to my mate at VW and the part number he can find is 034 905 381 or 034 905 381A are any of these correct? I put the part number into google and it comes up as a crankshaft pulse sensor?
    Check out this post (below) PN should be 034905161
    • BrianSmith_S2
      • Jun 2005
      • 1342
      • Home: Northern Ireland Current: British Antarctic Territory
      You mean one of these? The numbers youve been given refer to the crank position or speed sensor... the G40 is the cam postion sensor
      This is a photo of a broken one, it shows the audi and bosch part numbers
      Audi part number 034 905 161
      Bosch 0 232 101 020
      • avants2turbo
        • Feb 2008
        • 1287
        whats the best way (with description if pos) of testing the G40 sensor?
        • BrianSmith_S2
          • Jun 2005
          • 1342
          You need to put a 5V LED (i got mines, a CJ65V, from maplins http://www.maplin.co.uk/Module.aspx?...rderCode=CJ65V ) across pins 2 and 3.
          The signal output is on pin 2... thats the pin that should blink.
          Pull back the rubber boot and ease LED pins down into contact with the connector leads on pins 2 and 3. Ignition on and you should see pulses from the LED if the sensor is ok.
            Originally posted by BrianSmith_S2
            You need to put a 5V LED (i got mines, a CJ65V, from maplins http://www.maplin.co.uk/Module.aspx?...rderCode=CJ65V ) across pins 2 and 3. The signal output is on pin 2... thats the pin that should blink. Pull back the rubber boot and ease LED pins down into contact with the connector leads on pins 2 and 3. Ignition on and you should see pulses from the LED if the sensor is ok.
            Isn't this something that Paul N. has built as a plug and play tester?
            In any event, Avants2turbo's immediate issue is his connector is busted up. That said, he *could* still just connect the appropriate wires and their male-female spade connectors together, keeping them from touching with PVC electrical tape.
            • avants2turbo
              • Feb 2008
              • 1287
              do we really think that busted connector could stop the car from starting?
                If any of the three pins on the G40 are not working or are not connected properly, your engine is not going to start, end of story. As I suggested the plastic connector housing is not 100% necessary, if you were desparate and wanted to get the car started.
                • avants2turbo
                  • Feb 2008
                  • 1287
                  Worth a go then..
