AAn Ecu been socketed?!
  • Sleeper_Avant
    • 2372
    took my standard ECU out for general poking around purposes and noticed that its already been socketed and the chips just plug in and out, is this normal for a 92 AAN?
    very interested to see as cant find any info on this, need to take it to work tomorow and measure resistance to see if its been RS2`d,
    intrigued, Sean
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
  • s2_wot
    • Aug 2006
    • 2178
    Some ecu's were socketed from the factory AFAIK.
    Shane
    • prj
      • Mar 2010
      • 6308
      Yes, some ECU's are indeed socketed from the factory.
      Mostly the earlier ones from my experience.
      For the later ones it's a soldering job.
      Check that your ECU is not labelled 551A. If it is, you can't just stick any AAN chips in there, you'll need a custom boost chip.
      Measure R201... on RS2 it is 5.6k on AAN 6.5k iirc.
      • Sleeper_Avant
        • 2372
        Boost isnt a problem as its controlled outside the ECU via stand alone,
        Will be measuring various things tomorow when i take it to work
        cheers for this,
        Sean.
        • prj
          • Mar 2010
          • 6308
          And why?
          On stock turbo that is mostly ok, as long as you don't go over 1.5 bar.
          Then again, with stock software you will have fuel cut long before.
          Manual boost control, RS2 hardware and software without load limiter is how very many people have bent their rods or blown up their engines.
          If you run on your car what you have written in your signature, you will need either a standalone or very in-depth remapping and a different maf.
          • ian4455
            • Nov 2010
            • 787
            Would a 91 3b ECU be socketed from factory?
            • Sleeper_Avant
              • 2372
              ive been building very high power cars for myself and customers for many years, im not about to do any of the above for a few extra horsepower.
              im just relatively new to motronic ecu, id normally use autronic or DTA for better results on live mapping.
              i was only curious about the socketing thats all
              thankyou for the info.
              • prj
                • Mar 2010
                • 6308
                Just pointing out that keeping motronic without knowing how to map it and screwing with boost without at the bare minimum adjusting the last cells in the fuel/ign chip while some wannabe tuner turned off the load limiter in "tuned software that makes your car go fast" is the fastest way to disaster...
                Sorry, just my experience... I deal with such cases weekly
                Yes, all 3B are socketed.
                  Mostly the earlier ones from my experience. For the later ones it's a soldering job.
                  As far as I know, it was only the very early 92 model year UrS4s, e.g. ones built in the Aug 91 to Oct 91 period that have socketed ECUs. At some point, Nov 91 (?), they started soldering the chips without the sockets. There is no documentation on the breakpoint on this switch, unlike the location of the cam position sensor which changed location in mid-Feb. 92.
                  • prj
                    • Mar 2010
                    • 6308
                    Originally posted by UrS4boy
                    As far as I know, it was only the very early 92 model year UrS4s, e.g. ones built in the Aug 91 to Oct 91 period that have socketed ECUs. At some point, Nov 91 (?), they started soldering the chips without the sockets. There is no documentation on the breakpoint on this, unlike the switch in the location of the cam position sensor in mid-Feb. 92.
                    It was when the ECU's were swapped from 551A to 551AA. 551A is socketed, 551AA and 551B (the autobox one, not RS2) isn't.
                    That might not be 100% true of course, just my experience from pulling apart 30+ ECU's.
                      It was when the ECU's were swapped from 551A to 551AA. 551A is socketed, 551AA and 551B (the autobox one, not RS2) isn't. That might not be 100% true of course, just my experience from pulling apart 30+ ECU's.
                      That seems reasonable. Unfortunately, my good friend Kate no longer knows about the 551A version. In fact, as of 01/01/2002 she doesn't really even know about the 551AA version since it has been superceded to a rebuilt 4A0997551X.
                      Perhaps earlier documentation (prior to the 01/01/2002 date) would provide a VIN number break between 551A and 551AA.
                      Matters only to the obsessive parts trivia freaks.
                      (me)
                      • Sleeper_Avant
                        • 2372
                        Interesting there PRJ
                        wonder if Paul has any further info for you guys, if he reads this.
                        • porkkis
                          • 1994
                          I've also seen a few ecus myself and some later ones (let's call them series 2, ok? 551a = ser1) do have factory sockets. I haven't found a rule really. In some rare occasions they exist and still mostly not.
                          Dizzy ecus are indeed always socketed.
                          • Jonas_R
                            • 3780
                            • Country: Denmark
                            Can you give some more detail on this?
                            I mean does the 551A ECU run with a different resistor then ABY box or 3B for the matter?
                            Sleeper S2 Avant +450
                            A6 Avant 2.7t Stage 3
                            Audi S2 Coupe RS2'ed
                            • prj
                              • Mar 2010
                              • 6308
                              No.
                              Don't know about 3B, that is a totally different ECU, almost nothing in common with the newer ones.
