Hello,
I upgraded to KMS ECU and I have issues with Idle valve. It seems that if you want to get it right you should use KMS idle vavle as well, because orginal bosch valve has bigger resistance and it fry ECU controler.
I tried to get such valve but our locad dealer has none, also it's really hard to get one from KMS....
Any way the question is do you know a equivalent valve which I can use? I'm nt sure but I think that KMS basically used Pierburg valve but of course the part number is deleted since they sell it for KMS part
it's Pierburg
