As in title, removed the alarm, put all back together, runs beautifully, when i started it i got the flashing exclamation mark and beeps, then all the way home 20 ish miles constant flashing exclamation mark, the oil pressure and temp fine, coolant level fine, brake fluid level fine, only thing adrift was the voltage guage, i think the regulator i think is playing up, the lights pulsate with the guage flickering around 14v
Any ideas whats causing the exclamation mark flashing, also am i going to damage anything with the volts up around 14v?
