Hello, I've been runing a Gt3071 with 034 chips for a while on my ABY coupe without any problems till now...
The thing is that when I'm idling on a corner to take off my throttle completly stalls about 1500~2000 rpm, it doesn't turn off the engine, but it is like if i'm not pressing the throttle pedal at all. If I keep pumping the pedal it reacts again and I can keep running again from 2500~3000 rpm on but with this late reaction every time I press the pedal.
I ran VAG COM which didn't showed anything.
What could it be ? coil? fuel pump ? etc..
One more thing, is not always, sometimes the car runs fine, but suddenly it starts failing !!
Thanks!!!
Thanks!!!
