Running Problem Help
  • Tonks4x4
    • Nov 2005
    • 3062
    Ok chaps, yet another strange one....
    Drove an S2 from Sheffield to Nottingham with no issues at all.
    Removed the engine and put into a UR all done as normal.
    Engine starts but is overfueling like hell and then cuts out and wont rev above idle untill warm.
    It has had a new MFTS fitted and does not make a difference when unplugged.
    I have tried running without water sensor in the back of the head (No Difference)
    I have replaced a know good Maf (No Difference)
    I have tested and replaced throttle position switch (No Difference)
    The fuel lines supply and feed are definately the correct way around.
    There is no boost/vac leaks.
    There is no error codes at all. (Apart from G28 as usual)
    I am just about to swap the fuel pressure regulator but other than that I can't thing why it would pack up working moving from one engine bay to another.
    Any Ideas???
    Audi Nut!!!
  • Tonks4x4
    • Nov 2005
    • 3062
    Fuel pressure regulator makes no difference.
    Audi Nut!!!
    • sam80quattro
      • Oct 2006
      • 1496
      is it running on 5? i had similar bother with my 1.8t in my 90. and didn't realise it was running on 3 due to no exhaust lol but the problem on mine is the ignition amplifier. unplug it and put back in and all was fine
      • Knight Rider S4
        • 3541
        Sure you havent put a plug on the wrong sensor , probably something straight forward like that especially if you drove the car there all working
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • 220bhp
          • 2578
          • Home: United Kingdom
          I have had this issue twice when replaceing the engine on my 3b. first time it was the distributor cap,[somehow I damaged it replacing the engine.Second time it was plug leads the wrong way round.
          • Knight Rider S4
            • 3541
            Did you suss it out yet ?
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • Tonks4x4
              • Nov 2005
              • 3062
              Well I rigged up a seperate pump in a bucket in front of the car and all is well....
              So Replaced both filters, the acumilator and the pump. The new pump that was fitted supplied by the customer lasted about 10 mins and the seized up. So a pump was removed from my old 80 2 door, and it now lives as it should
              So had to give it a quick shake down round the local roads.
              I will try and get it for it's MOT on Monday morning
              Bosch 044 is on order for Tuesday morning
              So all should be cool....
              Audi Nut!!!
