Ok chaps, yet another strange one....
Drove an S2 from Sheffield to Nottingham with no issues at all.
Removed the engine and put into a UR all done as normal.
Engine starts but is overfueling like hell and then cuts out and wont rev above idle untill warm.
It has had a new MFTS fitted and does not make a difference when unplugged.
I have tried running without water sensor in the back of the head (No Difference)
I have replaced a know good Maf (No Difference)
I have tested and replaced throttle position switch (No Difference)
The fuel lines supply and feed are definately the correct way around.
There is no boost/vac leaks.
There is no error codes at all. (Apart from G28 as usual)
I am just about to swap the fuel pressure regulator but other than that I can't thing why it would pack up working moving from one engine bay to another.
Any Ideas???
Any Ideas???
