A friend of mine has a urs4 and am having trouble getting the engine started.
In vagcom it had no faultcodes, it gets gasoline but NO spark.
Only just a small amount when the ignition is turned on, but not when crancking.
He has changed, PAS modules, igniters, testet camsensor with a small lamp.
Checked the flywheel, all we havent testet is ecu and engine wire.
Any ideas?
Any ideas?
I hoped you would answer.
