V6 crank bolt size??
  • KRIMZONQUATTRO
    • Jan 2011
    • 32
    Hey there folks, stupid question number 1, does anybody on here know the size of the socket needed to remove/replace the crankshaft sprocket bolt (not pulley) on a 2.8 V6 AAH. It's a 12 point multi splined bolt. It's slightly bigger than a 24mm HEX socket (which I won't use but was used as a guide for the right size) but there is a slight movement with a 25mm 12 point socket.
    I can't tell wether a 24mm 12 point would fit but don't really want to waste another journey into town getting the wrong socket size....again. Or am I wrong and that the size I need is imperial not metric....
    If anyone can help that would be great!
    Regards
    Jay
    Pretty sure it is 24mm 12point from memory.
    BTW - you will not find one imperial fitting on Das Audi !
    Also - catch my other post re tensioners, pulleys and shiiiit
    • KRIMZONQUATTRO
      • Jan 2011
      • 32
      Perrrffect!! Well off to town tommorrow then
      Thats good to know about the imperial thing.
      And yes replied to your other post...
        Well your memory is good on the 12 point part (and I assume the 24 mm). My friend, Kate, isn't that helpful. All she tells me is the 078105229D "screw" is a 12 point socket head, M18x1.5x85
