While working today I wondered what the height difference was between the 5 pot short block (aby / adu etc) and the taller TDI block (AAT / AEL) and how does it sit in the b4 enginebay, is the sump very close to the ground or does it use taller engine mounts to compensate?
Also how much heavier is the stroker engine than the normal engine?
jamo is the man on this one.or andyp..i seem to rember that the block is 15mm higher.sump is ok,the extra height is the block...have heard it catches the bonnet slightly..weight should be same
The block is 16mm taller and all the extra height is at the top of the block so no problems with the sump. Mine clears the bonnet, just, by removing the trim at the edge of the sound proofing. The problems arise when you fit a reverse inlet manifold, then you have to start chopping the bonnet. Not sure on the weight but it's not a lot extra.
16mm is nothing, do you use the diesel sump or the petrol sump? I'm trying to imagine the whole lot assembled to satisfy my own mind.
I wrongly assumed the diesel block would be a lot heavier and was going to ask about suspension setups etc. I suppose even if it was 100kg it wouldn't be a lot. Thanks Andy
Thanks folks, I'll sleep better now (seriously ) @ Rocco, I know where theres is an engine and I'm thinking about the project. Maybe I'll take the engine just in case
