Rods AAL/AEL
  • Nik0las
    • 1345
    • Country: Bulgaria
    Rods AAL/AEL
    Is anyone thought about the fact that diesel rods are stronger then original ones in AAN/ABY/ADU and they can be switch easily? I know few guys running 550hp+ on diesel rods and stock pistons... Do you know somebody else, what are their thoughts about this?
  • AndyP
    • 6049
    I didn't think you could put stock pistons on TDi rods as the pin is much bigger?
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      AAT rods + oem S2 pistons in the AAT block??
        TDI uses a 26mm pin, crazy pistons would be needed it's just too big to be pratical
        see http://www.s2forum.com/forum/showthread.php?t=2480
        • Billman
          • 4129
          maybe you could use another sleeve? in small end of the rod in order to use a smaller piston pin but dont know if theres enough space under the piston for it to move.
          Another possibility would be to change this sleeve for lets say 22 piston pin and enlargen the piston pin hole for it.
          Then you sit and calculate the cost/benefit of it:
          Cost to modify the superheavy diesel rods VS cost of proven supercheap H-Beam rods.
          Go Holset or Go RS4
          • Nik0las
            • 1345
            • Country: Bulgaria
            you can use well made bush to fill in 20mm pin
              And what of pin lubrication and the fact the rod length is only 144mm when the doing the conversion you use rods between 155 to 159 mm
              • terrybullwon
                • Mar 2006
                • 8782
                And more to the point Scat and Aarons Rods are SO cheap why would you even bother?
                Chef
                  exactly that and they come in 20-23mm pin also
