Photo of the inside of an ABY Sump - please
    Does anyone have a photo or two of the inside of an ABY sump ?
    Also how hard and what's involved in taking off a sump for a healthy road going car, i.e. one that is not being parted or having it's front suspension components being refurbished.
    Thanks in advance.
  • AndyP
    • 6049
    Just in the middle of doing this myself, so I'll report back tomorrow as to how tricky it is.
    • cooperquattro
      • Jan 2011
      • 815
      PITA is the answer..engine up or subframe down
      • Avantus
        • Sep 2007
        • 941
        • Country: Belgium
        Not so great quality however.. and supposing that the ADU sump is the same as ABY
        Dit it again about last week, and on a ramp I did it in 30 minutes, nothing to it
        Just loosen the rear subframe bolts, and take out the ones in the front (4 times an 18)... it'll drop a fair amount so you can easily reach the ones at the rear of the sump.
        For getting it back on, the 2 you have to put in trough the holes in the gearbox can be a bit tricky though! Do those at the beginning, because when you drop them in the sump you can take it off again
        • cooperquattro
          • Jan 2011
          • 815
          most of us are on our backs here..no luxury of a ramp...looks to be no plastic baffle in sump as to someone elses post this week
            That's what I feared. Thanks.
              Originally posted by AndyP
              http://www.s2forum.com/forum/showthr...=removing+sump
              Any close up photos to show the areas inside is what I'm keen to observe. I want to work out what's left in the sump if one uses a pipe in through the dip stick to suck out the used oil when changing the oil and the oil filter. I also open the oil cooler connection pipes separately to get a bit more old oil out at this point in the oil system.
              "two grumpy kids and the odd fight with the missus about 'that bloody car".
              Loved this bit from Paul's write up seemed scarily familiar. His write up is has all of the emotion I experience when working on these S2s, he conveys it so well.
              Thanks again.
              • s2_wot
                • Aug 2006
                • 2178
                Can I ask why you are going to remove it David? Subframe down is your best bet imo based on what I was at today.
                Shane
                  Not wanting to take it off.
                  Just want to know what's inside.
                  Given your propensity for taking things apart to see what's inside, I await your photos of your sump, if that's OK.
                  Thanks, Shane.
                  • s2_wot
                    • Aug 2006
                    • 2178
                    From earlier today, tomorrow there will be sump photos for David
                    Shane
                    • AndyP
                      • 6049
                      This is mine from today. It's a tricky job to do with the engine in the car, not too bad getting it apart but trying to get the sump, gaskets and windage tray back on is very tricky. You need to patience of a saint!
                      • V6quattro
                        • Sep 2008
                        • 949
                        Are you sure this is from a ABY? My ABY sump didn't have a plastic thing.
                          Andy,
                          Perfect photos thanks.
                          Do you have a photo of the oil pick up ?
                          And was it clogged ?
                          Thanks again.
                          • s2_wot
                            • Aug 2006
                            • 2178
                            Opened mine today, the oil pickup was far from blocked but you can see the piece of metal swarf that was in there
                            Shane
                              Just a chip off the old block, nothing to worry about.
