brand new oil cap blating out oil. . .
    S2 Forum comes up trumps again!
    Glad you got it sorted!
      BTW did you check the operation of the little one way valve, item 10 above?
        BTW Newsh, i've named dropped you can you respond in this thread?
        • Rusty
          • 18953
          w50 for road use, w60 for track use. It's to keep the viscocity high enough on the turbo bearings. If it's all quite new, and you drive on teh road mostly, then w40 will be OK.
          • R31LLY
            • Mar 2011
            • 154
            yes i checked the whole system and everything is now fine thank you :-)
