brand new oil cap blating out oil. . .
  • R31LLY
    • Mar 2011
    • 154
    hello all. .
    my old oil cap was leakin oil all over my engine bay so obviously ive bought another but the problem still persists, i was wondering if thier was a oil cap with a higher pressure rating or if thier is a way someone has found out so its more secure and cant leak no more, cos this is annoying 2litres of 10-60 oil in 2 days just going to the floor :-(
    thanks in advance reilly!
  • moggies
    • Apr 2009
    • 158
    Is your breather system blocked?
    • R31LLY
      • Mar 2011
      • 154
      no i got a brand new breather on, were else could it be blocked in the system? it is like my engine must have way too much pressure in it
        What exactly have you replaced? have you cleaned out the breather pipes and cleaned the firetrap and replaced the PCV valve?
        • moggies
          • Apr 2009
          • 158
          Worst case pistons/rings issues, whats the mileage?
          • R31LLY
            • Mar 2011
            • 154
            ive got new pcv but not cleaned the pipes which ive just seen to do, im just lookin now in forums were to find the flame trap im just struggling to find a clear answer
            the car has 130000miles on the clock
              Sounds like a blocked breather hose or like the breather system is getting pressurised by boost pressure - Perhaps the 1-way valve has stopped working? That's at the rear of the engine, under the IM.
              Have you changed anything else, or is it all stock?
                • R31LLY
                  • Mar 2011
                  • 154
                  i bought the car in january ive changed a whole list of stuff to the car which ill list under this post if you want to read it
                  but
                  most recently ive had a new head gasket, new k24 hybrid quick spool turbo fitted, new breathers, 10-60 oil and oil filter and my car smokes on the over run mainly and if its left a few mins on idle it builds up if this give you any further clues
                  stuff ive done since january on the car...
                  -new radiator
                  -thermostat
                  -drilled and grooved discs
                  -ebc red stuff pads
                  -new vdo dials and speedo
                  -cambelt kit
                  -bottom pulley
                  -cam pulley
                  -camshatf sensor
                  -head gasket kit
                  -new belts timing, power steering and alternator
                  -denso ididium super tough spark plugs
                  -im currently waiting on a new lamba sensor to arrive :-)
                    10w60 oil is too thick you should be using 5w40 or 10w50 also get rid of those spark plugs
                    The audi plugs are the best for car so much so RS4 owners use them as an upgrade on their cars!
                    • R31LLY
                      • Mar 2011
                      • 154
                      im trialing 10-60 as ive read rs2's run it and i thought maybe with the hybrid turbo on mine it would need it maybe, i started with 5-40 which i thought made my car smoke but it seems to be this breather system ive over looked, so i may swap back to the 5-40 cos this 10-60 aint cheap ha ha i was looking for 10-50 oil but i could not find it when i needed it :-)
                      • fish
                        • Aug 2007
                        • 2333
                        I run 15-40 semi synth, Never had any issues...
                        www.garaget.org/fish for more pic“s of my cars
                          Positive Crankcase Ventilation (PCV) System with revised diagram, PNs and Links
                          i bought the car in january ive changed a whole list of stuff to the car which ill list under this post if you want to read it but
                          Sound like you have leaking valve seals if oil is pulled into the engine under vacuum (e.g. throttle off after giving it stick).
                          As for the oil blatting out, you are pressurizing the cam cover because the PCV valve and maybe the pressure regulating valve are Fubar'd. As a result, the orange arrow'd flow isn't flowing and pressure is back-flowing into the cam cover via the pink arrow'd pathway (only in reverse in your case). More info under diagram.
                          Have a read on this (it is for an AAN but the pieces and their function are the same for the ABY and ADU):
                          • Fat Audi 80
                            • 10547
                            I have made a seperate thread and hosted the above image and made it sticky, hope you don't mind UrS4boy?
                            Cheers,
                            Steve.
                            The Perfectionist
                            • R31LLY
                              • Mar 2011
                              • 154
                              thanks alot for all your help guys...
                              ive taken it all to bits tonight and ive cleaned it all out, i even pulled the flame trap out cleaned it and put it back together again, so far ive not noticed any more oil out of the filler cap which ill be keepin an eye on and instantly ive got no smoke coming from the exhaust so im a very happy chappy,
                              ever since i bought the car ive been fighting this issue and now its been resloved. ive changed all sorts, i even think the previous owner sold it cos of this and all it needed was new valve stem oil seals and a new pcv and breather lines cleaned out, they were full of crap but at least i feel ive full restored a audi s2 so im proud
                              now all i need is a good chip to compliment the k24 hybrid turbo and so i can put in my 2bar wastegate spring and get a lovely exhaust on
                              these cars are such a pleasure to drive when your not worrying about the smoke trail your leaving behind :-D
                              thank you all in this thread once again, for your quick and accurate help!!!!
                              R31LLY
