Help needed: ignition order / ignition timing ABY - AAN - ADU
  • Firebird69
    • Aug 2010
    • 83
    Hi everyone...
    I just finished putting an AAN together into an UrS4 and build in a free progammable control unit...
    The engine ran with the old original control unit and now doesn't start and doesn't ever trigger
    It got a ABY start - programm on it, so I'm guessing the the ignigion order or the trigger timing piont is diferent.
    Does anyone of you know? Help....
      thats from memory - please get a 2nd opinion
      • Nuno Cristiano
        • Aug 2010
        • 421
        • Country: Portugal
        I think 1-2-3-5-4
        .: MINI Cooper D 08' :.
        .: Audi Coupe Quattro 20V 91' :.
        .: Audi Porsche RS2 95' :.
        • Firebird69
          • Aug 2010
          • 83
          ok...that is the order for AAN or ABY or both
          and what is with the trigger-timing same or different?
          • Dan
            • Jun 2008
            • 1242
            This count?
            1993 ABY Coupe | BMW R1200 GS
            A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
              I think the firing order is actually cast into the head, 1-2-4-5-3.
              3B, AAN, ABY and ADU all have the same firing order.
              You should tell us what control unit you are using. There might be people here with that unit that could help you sort your problem.
                AAN Technical Data
                The attached should help.
                • Firebird69
                  • Aug 2010
                  • 83
                  funny Video...
                  Well UrS4boy...the control unit is a MME (maf-map-engineering) ECU481. So if anyone is using it. I'd be very thankful.
                  But I'm still asking myself about the triggering...
                    Hi everyone...
                    Are you using the standard audi trigger or aftermarket like 60-2 and what ecu are you using?
                    The firing order is as s2central says and correct it is cast into the head, obviously for the absent minded audi mechanics!
                    • Firebird69
                      • Aug 2010
                      • 83
                      the trigger is still standard Audi AAN...would it be different from ABY???
                        Audi trigger is very complex as it's based on 3 inputs
                        I doubt MME is configured to handle it
                        • Firebird69
                          • Aug 2010
                          • 83
                          oh well...I'll ask the control unit guy about it again...He said there are quiete a few running this unit in there l5 20VT
                          would suck if it won't work...
                          • prj
                            • Mar 2010
                            • 6308
                            It clearly says here that it supports it:
                            • prj
                              • Mar 2010
                              • 6308
                              I really like how this ECU supports a HFM to automatically fill the VE table.
                              Really cool stuff.
                              Here is something similar in piggyback form:
