Help needed: ignition order / ignition timing ABY - AAN - ADU
Sorry, I have to ask: Why not just use the Motronic ECU that the AAN originally came with? They can be modded to yield 380 hp at least (assuming appropriate hardware (turbo, injectors, MAP sensor) etc).RS2'd 93 UrS4 5 spd sedan
good question! with the turbo I'm aiming to hit 500hp and the main reason not to use the Motronic ECU from Audi is to be able to change thing around the engine easier...Comment
