Dizzy fitment
  • twoqu
    • Sep 2003
    • 3103
    Hi!,
    Sorry to hear that you are still having probs. Try here for some answers
    Pictures speak louder than words. You will need a multimeter to do some of the checks, but its less frustrating. Basically it is a process of elimination. Other than that you are going to have to learn how to pull the diagnostic codes from the ecu.
    Not sure what fuse you are talking about, but clearly any electrical component should be functioning. Would be worth checking for voltage at various sensors, most importantly the ecu itself.
    Was the car working before you changed the dizzy? If so, it can only be something you have touched to fix it. It would be worth checking something as simple as a fuse. The simple things are often overlooked!
    Good Luck!
    • mcandmar
      • Apr 2004
      • 5118
      I took a few piccys of the setup on my 7A before i took it apart,
      1st image is position of the dizzy in the head,
      2nd image shows the the two marks inside the dist..
      Both taken at TDC.
      Originally posted by Greenm3
      Having finally got my new dizzy........This may sound a bit dumb to those pros out there but how is it aligned?....
      Does is have to be set with the engine tdc?
      Any help please!!!
      Mike
      p.s on the plus side manifold and pipe polished....
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • mcandmar
        • Apr 2004
        • 5118
        2nd image,
        Any help please!!!
        Mike
        • audiman
          • 4827
          Good picture (no.2) Thats how it should be. It might be worth removing the immo to make sure that it isnt anything to do with that.
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • Greenm3
            • Jul 2004
            • 512
            Got it running now. Runs by itself, starts ok but very very lumpy. Almost sounds like a misfire and seems to be running very rich. A sensor on top of the im is broken. Any ideas why?
            Thanks
            • audiman
              • 4827
              Cos you broke it??? Which sensor? The inlet air temp sensor? How did you make it run?
              Audi UR Quattro
              • Greenm3
                • Jul 2004
                • 512
                p.s when turning the steering she tries to stall...im a bit low on hydralic fluid but i dont think that should afftet it (but i havent a clue)....bloody amatures.....
                • Greenm3
                  • Jul 2004
                  • 512
                  Yea i broke it! in frustration.......just kept turning it over while rotating the dizzy untill it started i had a feeling i was out. And i was! But it's that little sensor with the two allen bolts on top.
                  • audiman
                    • 4827
                    Thats the one IAT. ******, best get a new one then
                    Audi UR Quattro
                    • Greenm3
                      • Jul 2004
                      • 512
                      So would that make it run lumpy? ( I love these technical terms)
                      • audiman
                        • 4827
                        Maybe, what have you done to the dizzy? Where are the marks now?
                        Audi UR Quattro
                        • Greenm3
                          • Jul 2004
                          • 512
                          Basicaly ive turned it to where the car will start and run, which must be the correct position for it as it wont start at any onther orientation, i dont have much skin left on my hands!
                          • twoqu
                            • Sep 2003
                            • 3103
                            #28
                            Well done!
                            Not very scientific, but hell, it works!
                            So basically you didn't quite get the alignment right. Not surprising due to the marks located all over the engine.
                            • porkkis
                              • 1994
                              Double check the HT lead positions
                              Remove spakplugplug and see if one or more is wet
                              Remove injector plugs one by one when engine idling and listen if it makes a difference
                              • Greenm3
                                • Jul 2004
                                • 512
                                WEll having taken the morning off to sleep in i started on my diagnosis......it is misfoiring on cylinders 3,4 and 5 !!!!! and she still starts hahaha...thought i could smell fuel in the exhaust!!!! lol.....now i have to find out if its plugs or lead related.
