N75's work fine on 400+ hp cars.
Using the N75 you will have better spool.
Also:
If the mixture goes lean and there is knock, the ECU will be able to cut boost before your engine blows up.
If your timing belt slips a tooth, it will also be able to remove the boost before your engine blows up.
Comparing manual boost control with electronic is like comparing a carburettor with electronic fuel injection.
Don't dispute that, but it cant give you different boost per gear nor is it adjustable by the none motronic minded peeps. and it controls my water meth injection.
Please show me at least one controller with:
* Adaptive, mappable boost control based on RPM and TPS 3D maps.
* Adaptive, mappable per-cylinder knock monitoring
* Cylinder individual timing trim on knock events
* Knock event based boost reduction
* Altitude correction for boost
* IAT correction for boost
* Safe boost limit
And a myriad of other features.
There is no standalone boost controller offering this, that I am aware of. Of course today's ECU's come close, but not all.
Also, having the same boost in each gear is the "holy grail" of boost controllers... for obvious reasons.
* Safe boost limit
I can name you one that's unreliable...
I'm not disputing how good the N75 motronic system is but its certainly not the most reliable. I have replaced seven in my ownership of high powered Audi's and the majority have produced boost spikes when shot.
