2 knock sensors, 5 cylinders how does that work then?
  • s2_wot
    • Aug 2006
    • 2178
    This question just came to me while reading Lou's thread. So anybody tell me how the system decides where the knock is?
    Shane
  • Kieron20V
    • Mar 2008
    • 1505
    Flyheel position, timing?
    1994 URS4 Avant RS2+
    • driftin jo
      • Sep 2007
      • 2222
      It knows what cylinder is on its compression stroke.
      I'm not even sure if motronic does per cylinder timing retard anyway, it may just retard the timing for all cylinders if it hears knock. I'm sure someone will confirm if it has per cylinder retard or not but if it does like I said above.
      • s2_wot
        • Aug 2006
        • 2178
        Dmitri stated in another thread that the retardation was on a per cylinder basis, that's what got me thinking. I neglected to consider that motronic is looking at all the other details too. Thanks for the prompt answers gents.
        Shane
          G61 and G66 Knock Sensor info
          This info might help you:
          • prj
            • Mar 2010
            • 6308
            It does.
            • s2_wot
              • Aug 2006
              • 2178
              Is it possible then using vag-com or other method to log the instances of knock detection on a per cylinder basis?
              Shane
              • Ian Simmonds
                • Jun 2005
                • 2858
                do you have a doorbell in every room of your house?
                93 MTMS2 Avant
                • prj
                  • Mar 2010
                  • 6308
                  That is my wet dream, and the reason why I am sitting right now and disassembling the LDR chip in IDA Pro...
                  • s2_wot
                    • Aug 2006
                    • 2178
                    not at the moment but I might upgrade to a whole house system in the future
                    Is it something that can be logged on newer cars? By the time you're finished with motronic bosch wouldn't even recognise it What is LDR if you don't mind?
                    Shane
                    • prj
                      • Mar 2010
                      • 6308
                      Yes, you can log this on ME7.1 for example with ECUx.
                      LDR software is in 87C257 chip. Probably comes from the german word "lader" (charger).
                      • pixsaudisex2
                        • Sep 2004
                        • 3110
                        Yes why i live in a bed sit..
                          As in turbolader.
                            Tis good fun winding back the electrics from the car loom to where it interacts with the various chips inside the ECU... so that dmitri can focus on the right part of the matrix in the search of knock logging, hidden comms routines and such like. The more we learn about the complexity inside that 20yr old factory ECU the more amazing it is to think how advanced it was in its day - and still very capable today for silly power levels today as we slowly unravel the machine and discover how to do hitherto unmentionable things.
                            • Billman
                              • 4129
                              maybe Ladedruck as in Boost
                              Go Holset or Go RS4
