Right guys,
I have read through some threads and getting confussed with all the info.
Today, I was driving my s2 from work, everything seemed fine as I rolled along the dual carrage way at around 80. When I pulled up at a garage I noticed that there was blue smoke coming out of the exhaust
I checked dip stick and it was low so topped it up enough to get me home.
The gauges looked fine to me, temp was okay and pressure wasnt bad
I think that the turbo couldve let go or something as I had noticed that there was a bit of oil in the intercooler pipework the other day.
Im new to turbos and the s2 so any advice anyone has for me it would be great.
Is there a step by step procedure to check through.
I checked dip stick and it was low so topped it up enough to get me home. The gauges looked fine to me, temp was okay and pressure wasnt bad
I can't think of many other modest upgrades at the mo, the tried and tested one is a full RS2 setup but then you get into the debate about the 3B distributor and whether it's suitable for higher power...
