S2 Engine problem
  • porkkis
    • 1994
    Everything is possible concerning the boost leaks
    I'm planning to make a leak tester that will be attached directly to the turbo so the breather would not be pressurized and therefore I could use more pressure to test the system. Just drive a 500km for coffee visit (just as we did on saturday) when I'm ready and we could test your car
    • PekkaS
      • May 2004
      • 81
      No need for pressure testing any more... I changed all those 4mm hoses coming from im, and finally it works as it´s meant to.
      Just got back from motorway testing with Tommy. He´s using the same software as I do, and his car was obviously a bit slower...
        Originally posted by Greg_S
        that connects at the back below the IM manifold and the intake pipe. I think it is a one way valve related to the carbon canister and the PCV system.
        Its actually the one-way valve for the vacuum reservoir used by the rear diff lock and aircon (if fitted).
        Missing hoses here mean an air leak - in this case with unmetered air being drawn in at times perhaps.
        Paul
