I'm looking at a S2 Avant from 1995 (ABY engine) but it have an engine problem, it cuts out everytime you presses the gaspedal to quickly, I found a valve that seems to missing a hose, there 3 connections on the valve but only 2 hoses to it.
No i dont really have an engine problem, I only have, in high revs, that it makes a heavy noise, i dont think thats normal. Sometimes it starts a bit more difficult when the engine has had a cool down period of an hour.
Getting everything sorted out for my 5++ hp project
Ok, I could also tell the answer to the original question and not just be impertinent to Greg
On automatic aircon models there should be a black plastic pipe on the side entry of that check valve. Dunno if this applies only older style aircons and really don't have the energy to find out. However - seal it, otherwise you have a intake leak that doesn't really do good for mixture adjustment nor idling,
There are a hose on the "yellow" end of the valve + a hose on the underside of it but not on the "black" end, sorry I can't tell you more, the car is not mine (yet)
Hmmm... Could that be the reason to my "no-go" problems? Last time I did the pressure test, faint whistle came from that direction. What is that valve for?
It's a check valve so that no boost pressure can enter those two hoses - only vacuum.
But that valve is connected to intake manifold. So wouldn´t it be possible that the short 4mm hose from im to t-piece might be leaking and causing my problems?
