Oil in inlet track
  • rj scotty
    • May 2006
    • 2195
    Oil in inlet track
    Whilst doing a boost test yesterday I noticed a lot of oil in the inlet pipe work, MAF hose right through to the throttle body.
    What should I be looking at first?
    cheers
    rich
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
  • avants2turbo
    • Feb 2008
    • 1287
    Blocked oil breather system...
      With the stock PCV system in place there's always oil in the inlet tract.
        You need a catch tank system, stock system pumps a lot of oil vapour round the stock pipes
          Also gets worse as the engine wears (rings mostly) and the boost is turned up!
