RS2 - Engine Hesitation
  • steverrquattro
    • Oct 2006
    • 788
    Hi,
    I have a problem with the RS2 at present. When accelerating hard it seems to splutter/hesitate at around 4500 rpm. It will do this in pretty much every gear, however if you slowly accelerate through the revband, it appears to be OK. The car is running on Shell V Power. NB Once it gets over the hesitation it absolutley flies.
    I need to get this sorted now as it did it today during overtaking. Any ideas on what to look at and check?
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
  • peter sa
    • May 2011
    • 1
    sounds like plugs
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      Definitely sounds like an ignition problem around peak cylinder pressure, so check the plugs, as mentioned above, and check the connectors that sit on top of the plugs. check these with a multimeter.
      1994 80E Avant
      1986 2L Golf 2 on Alcohol
      • avants2turbo
        • Feb 2008
        • 1287
        How do you check them with a multimeter?
          Missing and Hesitation Diagnostic Procedures
          You might want to read this:
          As part of this more general 20VT ignition post:
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            Test the resistance with the ohm meter. supposed to be approx 5K Ohm if I remember correctly (it is printed on them)
            1994 80E Avant
            • steverrquattro
              • Oct 2006
              • 788
              I put some more Super Unleaded in today and changed the plugs...........and it's still the same.
              Tomorrow I'll do the resistance check and report back. I presume that if the resistance is greater than 5K then the coil is open circuit and therefore knackered?
              Are these expensive?
              Steve
              1990 RR 20V
              • prj
                • Mar 2010
                • 6308
                Sounds like a coil or POS channel to me, if plugs didn't cure it.
                4500 is pretty much torque peak.
                Alternatively you could be running too rich or too lean - hard to check that without WBO2.
                • cooperquattro
                  • Jan 2011
                  • 815
                  which car is the rs2 engine in??i thought the engine was for the swb??
                  • Golfboy666GTI
                    • Sep 2008
                    • 571
                    • Country: New Zealand
                    It sounds like an issue Ive had with two cars, dying fuel pumps both times.
                    1980 VW Golf GTI Track Car
                    1995 Audi RS2
                    • Fat Audi 80
                      • 10547
                      The other thing to check is coilpack (sparkplug) rubber boots. Are these in good condition? If not these will earth HT to the head causing misfiring...
                      Cheers,
                      Steve
                      The Perfectionist
                      • ADU_S2
                        • May 2004
                        • 164
                        Its most your mass meter, from what your saying i put my money on your mass meter being faulty/damaged. i had exactly the same issue last week where when i was putting my foot down the car was hesitating as if it was starved of air, then suddenly after a certain point i got full power.
                        If you know of someone close by with an RS2 just swap it over to test, they are quite expense to replace.
                        • Ross
                          • Aug 2005
                          • 3399
                          Lots of experiences here to draw on.. from my own, with MAF issues it's been a hard cut rather that hesitation; I had that under load and it was ignition - one time POS and the other a tiny nick in the boot as Steve suggested. The latter was fixed with some insulation tape.
                          • prj
                            • Mar 2010
                            • 6308
                            Check for faults as well...
                            You might have a christmas tree lit up there for all you know
                            • steverrquattro
                              • Oct 2006
                              • 788
                              I'm new to RS2's. How do you pull the codes on this car?
                              PS Anyone local to Doncaster willing to lend me their MAF for a few minutes???
                              Steve
                              1990 RR 20V
