Wastegate air leaking into exhaust
Got my wastegate reconditioned by Rich aka (Hoffer76).
Terrific job, looks brand spanking new and works a treat.
My old WG was definitely leaking air, mostly due to a tired original spring.
Here's a shot of the new one:
Attached FilesRS2+ (now sold...)Comment
The diaphragm was and still in good condition - no leaks - easily tested on anyone's WG by attaching a pipe + vacuum pump to the upper WG port.
I think this WG was previously leaking or bleeding air past the piston due to the tired original spring, which was allowing the piston to open sooner that it should, delaying onset of full boost.RS2+ (now sold...)Comment
Either diaphragm is toasted or if it is when you let off, the dump valve.
You got it wrong here and I will explain why. I already did once, but it seems that I need to do it more precisely.The diaphragm was and still in good condition - no leaks - easily tested on anyone's WG by attaching a pipe + vacuum pump to the upper WG port.
For that one needs to look at Audi's N75 topology.
The N75 has a restrictor in the middle port, which points towards the turbo.
That restrictor is there so too much air does not go through the boost control system, in fact the amount of air is miniscule that passes through there in the grand scheme of things.
So your assumption, that you have a boost leak in the wastegate and that it is somehow affecting your car is completely wrong.
Now let's go to the wastegate diaphragm. If that is broken, then your car will boost more, rather than less.
This is because the pressure that is going to the lower chamber and is supposed to work against the spring is escaping. Ever seen what happens if you disconnect the lower port? The same thing is happening when the diaphragm is broken.
The issue with the wastegate tends not to be the spring, but rather that it is possibly not sealing properly anymore, being effectively part-open all the time and bypassing exhaust gases even when not needed.
The "tired spring" myth is usually invented as an excuse because people can not find a blatantly obvious air leak or some other thing wrong with their car. They wind down the spring, and the car makes a bit more boost for just a moment, so they think it is the spring.
It is easy to jump to false conclusions when the base for your assumption is wrong.Comment
They leak air past the valve guide/bush when it is worn badly, they all leak a bit past even when new but this progressively gets more and more with wear. The other type of leak is as PRJ says , past the diaphragm (giving increased / overboost).
An bad air leak past the bush give you sluggish boost response in operation as exhaust gas goes past it and helps open the gate early/more. (I'm sure I've said this before)
Charmed.
You're saying the same thing as I - not sealing properly = bleeding past air.
Air can leak/bleed past due to wear and also due to shagged spring. Both checked out at service and working nice now.RS2+ (now sold...)Comment
I would not call exhaust gas air, and I have not seen any of the springs go bad.
But whatever.Comment
