Hi everyone,
First I want to apologize in advance for any typing errors and grammar that may follow:
I own a 91' Audi 200 with 3b engine.
My plans is to aim for aprox 400-450hp in engine with budget tuning. Im planning to run original Motronic ECU with a chip. The problem occured when I though of ignition, and 3b runs a singel coil and a distrobitor. The chip im planning to use is made for AAN/ABU/ADY ECU and will not fit in a 3B ECU. I also wich to use 1 coil per cylinder.
So I thought that "thats not a problem, I just buy a AAN ECU and problems solved.." WRONG! 3b wire harness dont match AAN ECU...
So im sitting here and wondering if anyone before me have though same idea and have converted their wire harness.
Additional info:
I have tried for a few years ago tuning a 10vt engine, bought only the most finest and expencive stuff i could find. This failed badly!
I have a lot of parts im gonna reuse, but Im not planning to build a new 034EFI again, because i have to remap it again and thats not a expense i can afford right now. A chip already have all this
Additional info:
