I'm finishing up my i5 20vt to 944 swap and discovered that the starter is dead. I can just replace it with another one, but I would like to know if there are any compatible units that either have the solenoid on the bottom or have a remotely mounted solenoid. Just looking to get some more distance between the downpipe and the starter since I have to replace it. Thanks for the help.
starter questions
starter questions
currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
see the AAN/944 swap at Nina's 20VTTags: None -
yep, that looks like mine.currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
see the AAN/944 swap at Nina's 20VTComment
so I guess that audi doesn't have a unit with either a remote solenoid or solenoid facing the ground when installed?currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
The solenoid is integral to the operation of the starter motor as it engages the drive pinion in the flywheel as well as switching the motor current.
To use a remote solenoid you'd have to try and find an old fashioned starter motor that uses an inertia type pinion for engagement that would fit.
Given how handy you are at welding, the simplest solution may be to part the starter motor housing just behind the mounting flange, rotate by 90 degrees or so and weld back up.
JohnComment
that is an interesting idea about cutting and rewelding. I will look at that closer, thanks for the idea.currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
