Ignition coils
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    #31
    all that conectors are the same. only must have 4 pin and be from Audi ,VW, SEAT,..
    when I need those conectors , go to place (don't know the how it calls - place with lot broken cars,which sales for a parts) and searching it on golf 5, audi c5,b6,b7, a3,seat leon...
    there is lot of those conectors , not only on ignition coil loom, audi b6 have each in every door, and 2 in trunk(one is on fuel pump) ...
    for 20 conectors I give them 15 euro , thanks , and goodbye .
    than I have it for 4 set of ignition coil.
    the problem is that cars are rear on place like this. they call me when some of then came... and I go to take conectors..
    • ian4455
      • Nov 2010
      • 787
      Originally posted by UrS4boy
      Good job. *IF* you followed this diagram from my original 2005 1.8t coil pack conversion DIY, there should be no problem.
      Ground for internal POS, this is just a perminant ground correct ??
        Originally posted by ian4455
        Ground for internal POS, this is just a permanent ground correct ??
        Yes. As per the diagram, you connect the ground wire to the cam cover, like the OE coils. You can run 5 individual ground wires but I wanted to cut down the bulk so I "T'd" (lineman splice) 4 of them (2,3,4, and 5) into one thick common wire than ran from the No. 1 (front) coilpack to the corner of the cam cover.
        • ian4455
          • Nov 2010
          • 787
          this is the same wiring for the V8 coil packs part number 06E 905 115 ?
          Pin 1 12V +
          Pin 2 & 4 EARTH
          Pin 3 to ECU switched ground
          correct ?
            Pin 1 12V +
            Pin 2 & 4 EARTH
            correct ? Thanks
            Yes, but I would run the Pin 4 ground to the cam cover and the Pin 2 ground separately back through the harness as per the OE POSs (probably ends up grounding on the intake manifold). I used a common Pin 2 groundline with 4 linesman splices as per the Pin 4 ground.
            The V8 coils that I am running are these (paid under $16 each):
            • ian4455
              • Nov 2010
              • 787
              Same coils I'm using also.
              • europeanme
                • Oct 2005
                • 3817
                thats a bargain Dave... and at that price I might ask you to get me some and post them.....
                Mike
                • SteveH
                  • 4460
                  What's the best price for these in the UK?
                  I need to buy five and I'd love to get them at US prices!!
                  91 Modded 3B
                  14 A6 Avant Black Edition
                  • RS2junkie
                    • Mar 2011
                    • 409
                    • Home: Ireland Current: Bahrain
                    #39
                    Hi,
                    I want to do this conversion on my RS2, just some questions.....
                    What is the current opinion on the best coils to use...
                    Can I still use the original rocker cover ?
                    Do the coils need to be modified to fit ?
                    Paul
                      Not much difference, I believe 06E 905 115 E is the most up-to-date version as shown above
                      Yes but you need to loose the coil cover or at the very least modify it to allow some ventilation - heat kills the COP type coilpacks.
                      No
                      If you need a harness let me know
                        In my very strong opinion the answer is 1001% ABSOLUTELY NOT. The heat will kill the coilpacks much sooner than later if you run the OE coil pack cover.
                        IMO, for an RS2, because of their rarity, you should run new OE coils and POSs to maintain the OE look and the value of your vehicle.
                        • Thuppu
                          • 4115
                          Haha. Another style to use VAG coils.
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            At least they got enough cooling
                              Okay, sure but WHY? That was the best solution to a coil problem? A "coil-on-plugwire" coil pack?
                              • Thuppu
                                • 4115
                                If there was no better available at the minute when he build that thing? Don't know the history, but it's 900hp build, and the guy putted togheter the latest engine in a short time.
