Which Option is Best for Plumbing ?
  • ian4455
    • Nov 2010
    • 787
    Which option is best for recirculated air from the DV ?
  • re2500
    • May 2007
    • 2185
    Doesnt look to be much difference to be honest. But i would say Pic 2 just because there will be less Jubilees. But not being the pressure side i can t see it making much difference.
    Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
    "Difficult is worth doing"
    • Thuppu
      • 4115
      Pic 2 is better, you get less air moving backwards to the MAF.
      Here is how I did it: http://koti.mbnet.fi/pro-ht/Audi_URS4/bypass-inlet.jpg
      • ian4455
        • Nov 2010
        • 787
        Interesting, that opens up my options to start with the pipework. Thanks
          Makes no odds really if you angle the input pipe towards the inlet of the turbo so the air is going in the direction of flow
          • Thuppu
            • 4115
            Worst scenario with the bypass-inlet close to the MAF and with high boosts, you got the MAF threads ripped of.
              The difference between the two means that it will occur on high boost applications no matter what agreed point 2 is the better location but in reality either place is the same in high boost apps
                Better to aim the DV return directly at the face of the turbo so it can do its job of keeping the turbo spinning. So pic 2 without doubt.
                • DS2
                  • 80
                  • Home: Jordan Current: Finland
                  i would also say pic 2
                  • Billman
                    • 4129
                    number 2.......you get a chance to give the compressor impeller a little push also apart from keeping tha maf safe.
                    Go Holset or Go RS4
