Can anyone confirm the o-ring part number for the 3b water rail? I seem to remeber qty is 3 but one of mine is torn or something as its leaking down the side of the block
I guess I should be thankful I found it now rather on the way to Le Mans next month
Drained down the coolant and pulled out the radiator/ac unit to get best acces to clean up and also reach everything i needed.
Pulled out the rail and basically the 3 o-rings i used when i refurbed everything about 3years ago had gone brittle and broken causing the leak on the 3 entry points. From memory I think I used Halford's ones from a huge box of different sizes.
Now replaced with OEM ones (thanks Paul) and a fresh larger gasket on the centre entry point.
Gave the radiator and a/c condensor a blast with the hoover - amazing how much rubbish comes out the fins and bought some decent flush to see if i can remove any scale/calcium inside the radiator.
Now just need to refit everything and fill and flush.
