Noticed with sorting my water manifold out that the two knock sensors which are bolted to the side of the block have cracked on the plastic outer which is bonded to the metal sleeve which the bolt passes thorugh.
While i have decent access I guess I should replace them but two things:
1) Whats the impact of them being cracked? They certainly didnt appear to affect performance or knock detection in that condition
2) can anyone confirm the part number of the longer, front sensor?
David
David
