Knock sensors cracking
  • s2driveruk
    • 12696
    Noticed with sorting my water manifold out that the two knock sensors which are bolted to the side of the block have cracked on the plastic outer which is bonded to the metal sleeve which the bolt passes thorugh.
    While i have decent access I guess I should replace them but two things:
    1) Whats the impact of them being cracked? They certainly didnt appear to affect performance or knock detection in that condition
    2) can anyone confirm the part number of the longer, front sensor?
    David
    1992 3b S2 Coupe
    G61 and G66 Knock Sensor info
    I think you are asking for electrical issues if the plastic is cracked. I would replace. Here is the info about PNs, etc. that you seek:
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      to be safe... change both knock sensors... surelly they are quite old and it derserves i think
      i replaced both on my car...and they were in good shape but i did not want to play with rthe risk of the dangerous knocks...
      they are not too expensive after all
      • Thuppu
        • 4115
        This is one of mine knock sensors:
        Does it work, I don't know..? It should be possible to test them by plugging them to your pc's soundcard, they should work like microphones.
        • s2driveruk
          • 12696
          yep mine looks the same and works fine but I think I'll change as i can easily get to them
          1992 3b S2 Coupe
          • orangepeel
            • Feb 2011
            • 205
            G61, BROWN 930mm 077-905-377 A or g61 .054905377a
            G66, GREEN 740mm 054-905-377 A
            org66 .054905377a i hope this helps bud
            • orangepeel
              • Feb 2011
              • 205
              g61 is the longer one 930 mm the brown one and g66 is the green one 730 mm
              • s2driveruk
                • 12696
                would ABY ones work in a 3b engine. they appear to interchange with several engines but the 3B ones have distinct part numbers. Presume its down to lead length more than anything else?
                1992 3b S2 Coupe
                • orangepeel
                  • Feb 2011
                  • 205
                  am not 100% sure but i think they would be the same 3b or aby i replaced mine on my 3b and theres plenty of cable mine cracked as they were originals i payed £30 a each for mine
                  • s2driveruk
                    • 12696
                    All of these not on general stock in the UK which is a PITA, along with G62 coolant sensor. Anyone know of any locations which might have them?
                    1992 3b S2 Coupe
                      Luckily I have done the hard work for you mate
                      Order them from your local Bosch dealer, they are like 1/3 the price of the dealer
                      • Bowlerwell
                        • 1052
                        Are these the same part numbers for ADU?
                        John Bowlerwell
                        Electronic Engineer
                        Present:
                        Nogaro Blue RS2 - TOE
                        Previous:
                        Kingfisher Blue S2 - UAA
                        Volcano Black RS2 LHD - DEX
