Engine sitting to low
  • hermanio
    • Jan 2009
    • 800
    im almost done swapping the engine from my competition for a ABY with 6 speed but i have a problem. the engine sits to low, now i cant mount my FARB because its hitting the sump (7a sump). also the sump hits the subframe. are the engine mount from an rs2/s2 aby higher ? when im looking to the snub mount it seems that the engine need to lift 2 cm. anyone knows this problem ?
    5 Cylinder Freak
    are you using new engine mounts? If not they are probably collapsed
    • hermanio
      • Jan 2009
      • 800
      could that cause a 2cm height difference ? i will take a look
      5 Cylinder Freak
      • mcandmar
        • Apr 2004
        • 5118
        Your problem might be the gearbox mounts pushing the gearbox and rear of the engine too high, what subframe and rubber mounts are you using?
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • Tonks4x4
          • Nov 2005
          • 3062
          I have found that S2 engine mounts are taller than 1.8, 2.0, 2.3 and all typ85 engine mounts,
          I suggest get a set of S2 ones should sort it
          Audi Nut!!!
          • Bruno
            • Jul 2007
            • 58
            • Country: Norway
            When i bougth engine mounts to my rs2.
            There was different part no if you have aircondsion or not. (on oem mounts)
            I dont know the difference.
            I bougth 034 street densyti and my engine rised up about 10-15mm(so collapse is possible)
            Hope this help
